RCU Forums - View Single Post - SAtio 100
Thread: SAtio 100
Old 05-04-2009 | 04:52 PM
opjose's Avatar
opjose
Default RE: SAtio 100
Since most engines supposidly come with the needles set from the factory, I often try to start new engines as they come.
I did this with my Saito 1.00.
I ran a few tanks through it, and began to slowly lean out the high end just a bit after every tank full.
After about six tank fulls ( 2 flights ) I had the high end set pretty well.
The low end was giving me NO problems, except I couldn't get the engine to idle slowly, with reliability.
I kept cranking the low speed needle in about 1/8th of a turn at a time...
Still the problem continued.
One person familiar with Saito's told me... "No, just keep cranking the LS needle in, until you can't even get a fast idle, then back it out."
So I did, ELEVEN ADDITIONAL TURNS!
This engine is SO tolerant of rich tuning that it will run slobberingly rich without fail ( except for the low idle ) and without cutting out.
After I found the LS setting a bit of additional tweaking made it run reliably ( but not too lean ), and now it sips fuel.
Along the way all my misfiring and backfiring stopped as well.
