RCU Forums - View Single Post - UAT Position
Thread: UAT Position
Old 05-05-2009 | 10:51 AM
AndyAndrews's Avatar
AndyAndrews
Default RE: UAT Position
ORIGINAL: hmarmaizmd
Hi! Andy. Then why I've seen a lot of guys placing it completely upright if the pickup
tube doesn't extend all the way to the back??
Hector
space limitations usually. It will work completely upright. In fact I have one in my F-16 that is completely upright. What you dont want to do is lay it down on its side (even with the fuel lines on top.
You defininetly want to be able to see the lines to check on them for air bubble leaks while running if possible. I always use clear lines on fuel for this reason.
