RCU Forums - View Single Post - UAT Position
Thread: UAT Position
Old 05-05-2009 | 02:11 PM
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: UAT Position
ORIGINAL: Ron S
Hector,
If you orient the UAT as Andy indicated, then when you refuel the model thru the UAT, you will displace the air bubble (with fuel) out of the UAT and thru the tank system. If the UAT is vertical and you refuel thru the UAT, you'll be starting with a bubble in the UAT already as you've noticed (under the screw-on cap). I don't think it is necessary to have all the air out of the UAT, but I'd say that less is better.
I orient mine as Andy states, whether it is a UAT, or a similar tank with a centered fuel filter...
Hi
I wonder to know, why the UAT is not as similar as a fuel tank, with a flexible hose with clunk that pick up fuel from its bottom?
If all the tanks and the one that works as UAT are filled full without air, why is needed an ultimate air trap? While this tank is full, being feeded by the other tanks, where is going the air come from?
Guillermo
