RCU Forums - View Single Post - Twin ESC's?
Thread: Twin ESC's?
Old 05-06-2009 | 06:25 PM
bassmanh
Default RE: Twin ESC's?
carl,
if its 2 brushless motors then you need an esc for each motor. and then you need to disable 1 of the bec's (battery eliminating circuit ) on 1 esc.
very easy to do just remove the red wire from 1 of the esc's (slip the pin out with a small flat screwdriver) and tape it back , that way you can use it again by simply putting it back in.
or use a small extension and clip the red wire on it and tape it back. much better than cutting the esc wire
bassman
