Don't fret, as you get some time on the ST it will start easier and as you lean it out, it will use much less fuel. Hey, you got it back in one piece, right?
Not sure if there is any ply in the bottom of the fuse strong enough to mount aluminum formed gear to, so you might be stuck w/ the wire gear. I'm sure it will be more fun as you get it dialed in to your liking!
