RE: TREX 500 FIRST HOVER WITH TAIL WAG
Also check the slop in your tail grips. You might need to do some tweaking on them if there is a large amount of slop back there..
Make sure you are not running in subtrim in your rudder. I have heard that this can cause some issues as well. Also make sure that you are using the gyro tape that came with it, or get some for your 401. I tried double sided tape and it was a nightmare.
