RE: Heli stuff and fellowship
Thanks Mike. I found the the pinions. The only ones to have it in stock was Venom themselves. The pinion is a 10T .4mod 2.3mm. Pinions such as for the Trex450 as an example are .5mod spacing. For those who may concider a Guai 200V2, the heli can use 2 cell 7.4 or 3 cell batteries. The stock motor plus 15T pinion and 2 cell gives a really good sportmils 3D set up. To have plenty of bale out power and blistering you need to step up to 10T pinion on 3 cells. I chose to go with 3 cell set up. It is interesting to note that the stock Gaui motor is hands down better than scorpion and other brands according to our factory pro here. There is a 5150KV motor that is supose to be good with the 2 cells.
Jim
