RE: Tiporare questions
Josh,
thanks for the pictures. One can see that your T-825 wing is quite a bit larger than the T-720. It's a little harder to tell how much larger the fuse is. Do you have figures (specs) for wing/stab span as well as fuse length (including spinner and rudder). The T-825 should do nicely with a "modern" RE 61 such as a pumped YS or OS. I imagine the stab is either flat or has about 2" of anhedral - is that correct?
I sent you a private message yesterday. You mentioned you were fairly new to RCU so I hope you received it. Let me know if not and perhaps I can write to you via email.
Thanks, David.
