RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 05-07-2009 | 01:49 PM
  #4755
Tired Old Man
Default RE: DL-50 engine
Before you do that try soldering a 1/8" id brass tube to a section of flat brass plate. Drill a hole in the brass plate that permits attachment to the face of the carb plate, orienting the end of the brass tube into and at the edge of the carb opening. Don't restrict the choke plate with the brass tube. The other end of the brass tube is connected via a section of fuel tubing to the opening in the diaphragm plate. No shipping costs and no parts costs for things you likely have laying around the shop now. The problem has nothing to do with the carb inlet design itself.
