RCU Forums - View Single Post - Engine tuning update?
Old 05-07-2009 | 06:27 PM
Phoenixangel's Avatar
Phoenixangel
Default RE: Engine tuning update?
Since it has had that much run time, I would do a couple things first and foremost, I would clean up the entire fuel system, replace the lines, clean the tank, remove carb and clean the ports under the needles. I would try a colder plug, pre-ignition can cause some funky running problems.
