RE: Converting .18tz pullstart to bumpstart
ya will also need the gasket set for the tz18 ya gotta pull the crank and cut the pull start pin off the crank, be very careful not to hit the rod journal with the dremel tool, use a piece of fuel tubing cut to lenght and slip it over the journal so it saves the journal if you do slip. i have 2 os cv15's and 2 cv18's that are non pull start conversions. i think a motor idles and holds tune better with a solid backing plate.
