RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 05-08-2009 | 12:51 PM
  #4774
Junaid Ali
Default RE: DL-50 engine
Hi Joe
I removed the tail wheel assembly and checked its Wt its 50 g, havnt replaced it though. Managed to get rid of 160 g nose Wt by moving the Rx batteries forward on the side of the engine box. I will put on the 22 x 8 JXF and give it a try this Sunday. Our field is located at 600 ft ASL but the ambient temperatures are very high around 110 F, I am hesitating to lean the engine fully it will probably overheat or should I lean it to peak RPM ?
Thanks for all your input guys.
Take care,
Junaid
ID:	1194499   Click image for larger version
ID:	1194500   Click image for larger version
