ORIGINAL: Junaid Ali
Joe
I will re-tune this Sunday at the field with a 22 x 8 on it and check the RPM, do you think the DL-50 can provide sufficient thrust for IMAAC aerobatics at 19 lb Wt.
Junaid
You should be getting about 7200+/- RPM peak on that prop.
The DL-50 with stock exhaust has plenty of power for IMAAC on that plane.
