RCU Forums - View Single Post - Getting back into RC
Old 05-10-2009 | 01:03 PM
clpahodges
Default RE: Getting back into RC
I had a slight (well, maybe not so slight) problem come up today. After several flights, while removing the wing from the fuse, I discovered fuel all in the tank and radio compartments. I immediately soaked up all that I could and then looked for the source. At some point during the day's flying, the tank had split about 1/8" at the top front where the tank halves are joined together.
I have removed the radio gear and applied K2R twice with good results and will let the fuse sit for a day or two with Speedi-Dry in it to soak up what is left of the oil. All the radio gear is fine. Doesn't appear that there will be any damage to speak of.
This was a brand new Hayes tank that I pressure tested for leaks after getting it set up. Anyone else had any problems with the Hayes tanks?
Oh well, stuff happens!!
Bill H.
