RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 05-10-2009 | 04:30 PM
  #4784
mstam1971
Default RE: DL-50 engine
ORIGINAL: The RC Dude
What about a tuned pipe or can muffler. Does a tuned pipe give the mid range or just top end.[] I have been thinking of replacing the stock DL 50 exhaust with a pipe of some kind but I am not sure what to get.
A canister can give a little performance increase. A tuned pipe gives you somewhat more in the mid range and much more torque at top rpm, up to 30%, and about 10% more thrust at full throttle. You hear people about pipes making the engine peaky and that's because it performs best at a certain rpm the pipe is tuned for. You definitely need to program a throttle curve in your radio. If you don't, one click of throttle increase is the difference between a hover and going straight up like a rocket.
I recommend the MTW header and RE2 pipe because it performs extremely well and is relatively light. My second choice would be the ES Composite pipe.
