RCU Forums - View Single Post - pz corsair maiden
Old 05-10-2009 | 10:34 PM
brett65's Avatar
brett65
My Feedback: (18)
Default RE: pz corsair maiden
ORIGINAL: maerlma
will futaba micros work with a spektrum radio?
Yes, all servos are pretty much interchangeable with each other now. You may have to cut off the little tab on the side of the servo plug. If the gear is stripped, no amount of glue will help it. Mine stripped too on my corsair, and Horizon sent me another servo. If they won't, the gear set is only $2 and easy to replace. If you move your ailersons up and down by hand when disconnected, you'll see that the ailerons are actually pretty stiff. This may be why they strip easily. I worked mine a lot by hand to free them up. I don't think that the servos are as bad as many people say they are.
