RE: Something wrong!?!?!? WIERD!
at a 1st guess from seeing what ya have.... i would say the spur side bearing on the slipper/brake shaft has went out and let the slipper shaft creep out some ... most likely i trashed your idler gear, the slipper shaft gear is metal ..... hope this helps!
