RCU Forums - View Single Post - what happened to the 4.5 post -its gone ?
Old 05-11-2009 | 11:55 AM
johndou
Default RE: what happened to the 4.5 post -its gone ?
ORIGINAL: LDM
I was getting advice in the 4.5 and its add ons and now its gone ??? Last post was a nagative one I guess its true , dont post a negative or honest opinion because thats what i read before all the post were removed ??? wierd !!!!!
I guess I'm responsible for that. de Rock has told me that what; "...you did was ignore the topic of the thread." The Topic, of course, was Real Flight G 4.5.
Here's the answer to your question direct from the KnifeEdge website. I might also suggest that you visit the KnifeEdge site directly for such questions. Their site is filled with helpful tips to get around some of their software issues as well. http://www.knifeedge.com/forums/
[quote]Original: KnifeEdge Software
Q. HOW DO I INSTALL CUSTOM CONTENT?
A. When you have downloaded the file you want from our swap site, load RealFlight. Select the "Simulation > Import > G3X" menu item in G3.5 or "Simulation > Import > RealFlight Archive" in G4 and G4.5. In the import dialog box that appears, locate the file you downloaded and open it. RealFlight will import the file. In G4 and G4.5 you can select more than one file to import at one time. Do not attempt to put custom content in RealFlight's data or documents folders; this will not work.
