RCU Forums - View Single Post - Tiporare Build
Old 05-11-2009 | 10:39 PM
  #135
doxilia's Avatar
doxilia
Default RE: Tiporare questions
A couple of snaps of the empennage. Elevator edges will be lined with 1/32 ply once the stab is mounted in order to be certain that they are clearing the rudder. At a glance, it appears that the angle at the elevator root is too shallow. A little wood filler still needed to conceal the wood quality difference at the TE of the stab tips. 1/32 ply inserts are located here to prevent the tips from denting. Elevator TE's are similarly lined with 1/8" mahogany - rock hard.
David.
ID:	1196651   Click image for larger version
ID:	1196652   Click image for larger version
ID:	1196653   Click image for larger version
