RCU Forums - View Single Post - Tools for Builders
Old 05-12-2009 | 03:56 PM
DonStegall's Avatar
DonStegall
Default RE: Tools for Builders
The other tool is a shearing wire cutter. It will cut wire up to 5/32" in diameter. It uses a big allen screw that drives a lever that has hardened steel bushings on each side.
It will cut piano wire very easily and it doesn't shoot it across the room.
I know you can use a cut-off tool, but this is quickier, much cleaner, and safer.
ID:	1196934   Click image for larger version
ID:	1196935   Click image for larger version
