RCU Forums - View Single Post - fuel filler
Thread: fuel filler
Old 05-12-2009 | 04:02 PM
ChuckW's Avatar
ChuckW
Default RE: fuel filler
ORIGINAL: millertym2000
I'm fixing to set up a 50cc yak, can I run a 2 line system and on the line going to the carb put a T and put the fuel dot on it with out any problems?
I assume that this yak is using a gas engine? If so, you can just put a "T" in the line from the tank to the carb and use a fuel dot. You can do this on gassers because of the pump-type carb. I've also done one with 3-lines because it just seemed easier for the particular installation at the time.
