RCU Forums - View Single Post - fuel filler
Thread: fuel filler
Old 05-13-2009 | 12:48 AM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: fuel filler
ORIGINAL: gaRCfield
ORIGINAL: millertym2000
I'm fixing to set up a 50cc yak, can I run a 2 line system and on the line going to the carb put a T and put the fuel dot on it with out any problems?
If you do this, fuel will go to your carb as well as your tank. I had this setup, and found it best to hold my throttle-kill when turning off my plane, so that when I refilled or defueled the carb was closed and I was only pumping to the tank.
Also, you probably will not have to prime your engine as you will be force-feeding fuel right to the carb when fueling.
Sorry millertym, I missed the part about the engine being a gasser. I was sharing my glow engine experience.
