RCU Forums - View Single Post - Tools for Builders
Old 05-13-2009 | 09:43 AM
DonStegall's Avatar
DonStegall
Default RE: Tools for Builders
Are you cutting fiberglass cloth with scissors? Cutting 3/4 ounce cloth is a pain. But there is an easy way.
It's called a [link=http://www.houseofpylon.com/Tools/RotaryKnife.aspx]Rotary Knife[/link]. Using one of these to cut cloth makes it so much easier. You need a cutting pad. But you can cut on masonite, or even cardboard.
I use these all the time. For cutting glass for wing center sections, for parts to lay-up.
They even work well for cutting plastic coverings.
ID:	1197272   Click image for larger version
ID:	1197273   Click image for larger version
ID:	1197274   Click image for larger version
