RE: dazzler arf
so i landed it rolling. it must of hit a bump and jumped in the air. when it got down it broke the front clean off. so the landing gear area is plenty strong. the 1" area that holds the fusalage is a nother issue.the whole front part that has the tank broke clean off. with the wing sunk in so far and the "bolt on" bottom hatch the top area of the fusalage in front of the wing is real weak it seams.
matt bounced his twist in a bunch of times. i roll it in and it is dead on one hopp.
it is getting plywood joining the front of the wing pocket to the rear wing pocket.
