RCU Forums - View Single Post - reversing y harness?
Old 05-14-2009 | 06:52 AM
CGRetired's Avatar
CGRetired
Default RE: reversing y harness?
ORIGINAL: overbored77
Dick,
Hitech08419 is setting up a Greatplanes Patty Wagstaff 1/4 scale extra (we have been discussing this setup through PM), given the size of this plane and size of the control surfaces I think the dual servos for the elevator would be the best bet Shorter non flexible control rod is better for large counterbalanced surfaces. I read the manual for the DX6I and found nothing about a mix for dual elevator servos. If you could peruse the manual that came with yours maybe you can find something about dual elevator servos. I reccomended a Matchbox or Smartfly Equalizer2 so he could properly reverse the servo and set end points. if his radio has a dual elevator mix the reverser isn't needed, but again I couldn't find
anything in the manual.
Well, Chris, that's not what was in the OP. We are not mind readers and try to offer comments that may help such situations. NOW that I know what you guys are doing, then parhaps I can make comments and suggestions that are more applicable.
Besides, this is a beginners forum, and this does not sound like a beginners topic.
CGr.
