RCU Forums - View Single Post - Tamiya Leo 2 instructions
Old 05-14-2009 | 06:45 PM
CapnCrunch43's Avatar
CapnCrunch43
Default RE: Tamiya Leo 2 instructions
*All transmitter references are with the Futaba Attack 4WD, set up according to the manual.
Movement
Left Stick: Stick Up=Hull Forward Stick Down=Hull Reverse Stick Left=Turret Left Rot Stick Right=Turret Right Rot
Right Stick: Stick Up=Cannon Up Stick Down=Cannon Down Stick Left=Hull Left Stick Right=Hull Right
Turret Weapons
Right Stick UP/DOWN TRIM fully up=Main Gun Fire when Right Stick is pushed up quickly
Right Stick UP/DOWN TRIM fully down=Coax gun fire when Right Stick is pulled down quickly
Light Modes
Left Stick LEFT/RIGHT TRIM fully left=Rotation Light ON/OFF when Left Stick is pushed left quickly.
Left Stick LEFT/RIGHT TRIM fully right=Cycle through B/N light modes when Left Stick is pushed right quickly
Left Stick LEFT/RIGHT TRIM fully right AND Right Stick UP/DOWN TRIM fully up=Select B/N light modes when Left Stick is first pushed right and held, then Right Stick is pushed up quickly.
Tank-Engine ON/OFF
Left Stick LEFT/RIGHT TRIM fully right AND Right Stick UP/DOWN TRIM fully down=Tank-Engine ON/OFF when Left Stick is first pushed right and held, then Right Stick is pulled down quickly.
DMD panel
VR1 = Channel 3/4 dead band range trim (R stick UP/DOWN - L stick LEFT/RIGHT used if Main Gun or Turret move when Trims are moved)
VR2 = Main Gun UP/DOWN TRIM (when tank is started or back deck switch is activated)
VR3 = Speaker Volume
PW-ST = Motor Power Setting ST=Standard mode PW=Power Mode
N1-N3/B0-B3 = Indicator Lights and Switches for Battle Mode Lights (B) and Non-Battle Mode Lights (N)
L M H = Tank Recoil Movement and Main Gun Fire interval
L = light tank/large recoil/3-5 second reload time
M = medium tank/medium recoil/5 second reload time
H = heavy tank/small recoil/9 second reload time
Hope this helps.
