RCU Forums - View Single Post - Stinger Build Thread
Old 05-15-2009 | 04:14 AM
  #52
DonStegall's Avatar
DonStegall
Default RE: Stinger Build Thread
Scott,
You may already use this method, but I wanted to share something I learned about using the [link=http://www.houseofpylon.com/Tools/HoleSaw750.aspx]3/4" Hole Saw[/link] to cut holes in wings.
If you press the hole saw down so that the teeth are seated, then turn the saw backwards until you have a nice groove, then possibly work it back and forth, you will get a real nice clean cut.
If you try to start out turning it forwards, it tends to wander and tear up the surface around the hole some.
I recommend practicing on a scrap piece of foam with some balsa glued to it.
