RCU Forums - View Single Post - TTn first mod?
Old 05-15-2009 | 12:31 PM
bikeracer
Default RE: TTn first mod?
ORIGINAL: Generalfred
I've got a bone stock ttn. What's the first mod I should do? Servos, forks, dampener.....?
Make sure the chain has some slack in it.
Check the rear shock bladder,often chewed up on assembley.
Softer spring and thinner shock oil.
Fit a fuel filter with a fine mesh,not one of those with a disc of brass gauze in.
Buy aftermarket air filter or keep repairing the standard one when the foam comes off.
Plug the filler pipe after filling the tank.
Better tyres once you've learned to drive it,the stock tyres are okay if you're only bashing.
Don't run it without the bodywork on,you'll just bend and break things,the bodywork protects the frame a lot.
