RE: gas to glow
Well I got got back from flying my uss weight is 14lbs. I cant get the grin off my face. It didnt miss a beat and pulled real good for a stock carb. My new carb wt499 should be here this week and we will see if i can get it to tack better then 7000 with an 18/8 prop. The enging was shaking at an idle but i read that the pump cover gasket would cause this if it was installed wrong like mine was now it will idle at about 2500 and not shake the plane to death. Again thank you all for your help in this endever. I will keep you all posted to see if my rpm comes up with the new carb thanks again michael
