RCU Forums - View Single Post - Ugly Stick Build
Old 05-15-2009 | 11:03 PM
  #120
Nergall
Default RE: Ugly Stick Build
Well, I've just about polished off all the little details you can't see in the pictures.</p>
1. Added the tailskid / lower fin, whatever it's called.</p>
2. Soldered up some 4/40 links for the ailerons.</p>
3. Ran the fuel lines and added some foam around the tank.</p>
4. Finally pulled the receiver out of the Kadet and sat down to check and program everything. (What should I set for Flaperon %??)</p>
The throttle cable is a little loose, so I need to add one more support near the servo. (Up front, I let some solder flow down the cable about an inch.)</p>
Then I just need to zip tie the battery and receiver in and make a hole for the antenna. I checked the balance earlier, but have added a couple small things since then. It should still be a little less than a half an inch on the nose heavy side. I like nose heavy for an initial flight. If you've ever flown something tail heavy before, you'll know why. In my case, it was only about an 1/8 inch too far back. (Park Flyer though)</p>
However, the weather looks iffy in Atlanta this weekend, so probably won't fly it till next week anyway.</p>
</p>
