E-Flite F-15 HELP!
Hi all!
I need some help/advice from those who know....
I need to know if I have a workable setup for a new EDF jet. Allhardware I plan to getfrom hobbyking.com.
Fan unit: 7 blade 2.5" 64mm Part number: 0R003-00108-7B
Battery: Rhino 2250mah 3S1P 11.1v 25c OR 2200mah 4S1P 14.8v 25c
Speed Control: Turnigy Sentry 40amp
Motor: HXT 2835 3900kv
Says motor is good up to 12v, but will 14.8v really be a bad idea for it??
They will be mounted in Eflite's F-15 twin, so there will be two of everything.
What I want is a setup that has plenty of power for as close to unlimited vertical as I can if that's even possible.
Any idea on what I can expect for thrust with this setup?
Your help is much appreciated!
Thanks!
