RE:
All,</p>
I have the plans and the construction article. I you will pm me with your e-mail addresses I will forward the pdf files, about 8 pages if I recall correctly. Most of the article preaches light, light and more lightness! I have the plans and have considered building this plane. Cowl is available from a couple of different sources, check Fiberglass Specialties and I have forgotten the others. Construction is very old style and looks to be a rather heavy build. New ideas may lighten it up a bit. A lot of fiberglass mesh sheet used in place of plywood, not even sure if the product mentioned in the plans is available any more.</p>
