RE: The Swee' Pea is next
Here is the top of the wing with all of the structure in place. Everything is glued down except the spar. The ribs were CA'd in place as were the pieces in front and behind the hinge line. These pieces seal the wing from air entering from the hinge. The torque rod bushings are just tacked down with CA to keep them from shifting during the join.
Don't know if I'll have time to take any pictures of the glue. If I can, I will. I have to fill the edges, and then put it on the structure, and finally run a bead around the edge. This is the part of the process that makes a wing usable or a piece of trash.
