Originally posted by rajul
Mark, I am looking at Dubro's new HD control horn for the rudder. Part number is 867. It's pretty new and looks quite similar to MK's setup. I am checking out on the weight as it uses a 1.5" 6-32 bolt. Much simpler to install compared to the nylon horn
That should work great but might be overkill. I can't recall the brand I used but it basically is a 6-32 screw that threads through two small plastic pieces that are shaped like a kite. Not much more weight than the stock control arm. Let me know if this makes sense. I can take a picture of it if you need. It's held up well for all the thrashing it gets and shows not signs of bending or stress at the attachment area.
The new Dubro HD set up looks very impressive. I have a friend that is installing their new pull-pull kit (similar in design to the 867) on a 36% 3W Extra.
