pull start woes???
does anyone know of any tips or trcks to eliminate the process of removing the body of your truck to pull the starter. i tryed bending the body up as far as i could , but had trouble with good cordination w/ pulling the pull start. i was thinking if i could make a hole n the body and somhow line the hole w/ somekind of metalring or gromit/ so when you pull the starter it doesnt cut the body w/ the pull or the re-coil. cause i hate having to remove the body to start the thing. an ideas will b
e debated. thanx, clay unruh
