RCU Forums - View Single Post - How to choke an Evolution 26 inside a cowling??
Old 05-20-2009 | 03:22 AM
SpaceCowboy
Default RE: How to choke an Evolution 26 inside a cowling??
Hi; Try putting your finger over the exhaust when you prime it or make carb plug on a rod that your ground crew can hold over the carb while you prime the engine.
I have the same problem with my 1/3rd Cub andI now use a primer bottle which is made in England butI bought it at Toledo. It has a nice small shut off valve on the end of the nozzle.
Good luck.. </p>
