I changed the chokeshaft and put a detent ball and spring in it, got rid of the return spring to make it work like the choke on my other gas engines. here's the part numbers you will need:
<span style="font-size: 10pt;" arial="" sans-serif="">ea 40-922-1 Choke Arm Shaft ($3.82)<o
></o
></span><![endif]><p style="margin-bottom: 0.0001pt; line-height: normal;" class="MsoNormal"><span style="font-size: 10pt;" arial="" sans-serif="">1ea 89-13-8 Steel Detent Ball .125DIA. ($0.41)<o
></o
></span></p><p style="margin-bottom: 0.0001pt; line-height: normal;" class="MsoNormal"><span style="font-size: 10pt;" arial="" sans-serif="">1ea 98-162-7 Detent Friction Spring ($0.49) <o
></o
></span></p>Find any local mower or saw shop and get them to order the parts for you.
JT<span class="info"> </span>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type"><meta content="Word.Document" name="ProgId"><meta content="Microsoft Word 12" name="Generator"><meta content="Microsoft Word 12" name="Originator" /></meta></meta></meta>
