ORIGINAL: jamiechip
hi there is there anyone here that can help me with reinforcing my funjet as you are all quite noligable with the funjet i thought this might tbe the place to come have a look i dont want to over weight the plane i have done the carbon spar in the wings i wonted to know what else you are all doing the ailerons need reiinforcing but whats the best way to do it i have thought of glassing the hole thing but it comes back to the weight issue any help would be great
Check your PM box
You don't want to glass the plane as it adds a lot of weight. With the mods I PMed you on a 4 cell 2500ma lipo 4.74x 4.75 APC prop and a 2900 kv motor you will be doing 110 mphplus level passes easy if not more
List you current motor or one you plan to buy and I'll get you a good set up. ESC also Should be 60 amp min.
Cp
