RE: dazzler arf
so the other day i flew it ok landed , went to take off and it darted the other way and i had to bail from the take off. well it was not good and the back behind the wing broke clean off. so i glued it back together recoated it (patched it more like it) had to get two servos cause he did not have gears for the jr47s.</p>
today was a good day. up3 times and 2 dead stick landings 5 or so min into the time.i took home a whole plane today wohoo. we drilled holes in the landing gear to weaken it and one dead stick was ploping it in a field. i stalled it out about 1ft off and itworked good. thegear bent some ,piece of cake. i went from a 11x6 to 11x5 and the super tiger runs better.</p>
now a question. i ended up getting monicote cause no white in ultracote. the monicote acted like it did not want to stick to the coating on plane very well or the plywood. i cleaned the planes surface more than once. it is like they do not like each other. also the dazzlers covering when i pulled it off felt like a tape adhesive on the back.</p>
and on the ground it seems hard to have it roll strate.is this a dazzler small tail wheel thing or do i need to look at something. it is not a pulls left a bit i need right rudder thing. it is like the plane is going where ever it wants and i have to try to get it back before it gets air or hits something. it happened again today but it was not in the air going at a big object this time(why i broke the back off last time)</p>
any ideas? it was a fun night. i like flying it and am getting handy putting it back together.</p>
