RE: Stinger Build Thread
This morning the servo tray was cut out and installed.
The tray is made from 1/8" thick plywood and it was glued in place using Shoo Goo.
6/30/09 Comment - I ended up adding tail weight to get the model to balance. You should locate the servos as far back in the radio compartment as you can. Possibly locate the rudder and elevator servos in the far rear. Then locate the engine servo in front of the 2 servos.
