RCU Forums - View Single Post - Webra 12 Pattern Project
Old 05-25-2009 | 09:19 PM
doxilia's Avatar
doxilia
Default RE: Webra 12 Pattern Project
Now we're talking... seriousness is the word I'm thinking of.
David, have you seen Mark's mini pattern creations over in RCG? He's scratched 50% Curare's and an EU-1A which look like little works of art! Those are electric powered which makes things a little easier - no exhaust to deal with. However... I've just been taking a look at these plans (save as .pdf).
I'm not sure if Walter would consider the PP 15 a pattern plane or a speed sport plane but whatever the case, the header and pipe that Ihave would actually fit right through the fuse. Question is, whether that will melt everything else inside!?
A 2-3 oz tank under the header and glassed pipe compartment with cooling slots along the top. The tail servos could go behind F3, the aileron servo is fine mounted inverted, the battery could go under the tank (I think) and the Rx in the front part of the belly pan. Doable, sensible?Dunno.
David.
File Type: txt
