Rafa,
I'm glad you caught this thread. I thought you might enjoy seeing that little engine. Iassume the pipe is the same as the one you used on your Pico and Magnum 15, right? It's an unmuffled straight 10" pipe.
Well, the first thing Idid was to unroll the Pico plans but with the header Ihave it just wasn't going to work nicely. The only reasonable thing to do was to source a fuse top header, which would have to be custom made and likely expensive, and mount the engine normally on its side with the pipe down the side of the fuse. Very doable but in the absence of that header...
On the other hand, I may have located a side exhaust muffler for this engine (cool thing brings the exhaust from the back out to the side) but that would defeat the whole ingenuity of the project and the revving of this little speed deamon - and that's why I bought the gem!
However, if Ibuilt the Pico with Illusion mods... now there's another idea. The arragement would be very similar to the Brushfire. The build would also be much simpler. I'll have to unroll the plan again...
David.
P.S. How're your projects coming along?
