RE: Starter battery setup
I ordered two 6C 7.2v 3400 mAh NiMh packs and a y cable to connect them in series. This will supposedly fit inside the hobbico case the lead acid is in. I'm trying to figure out how I can go about charging these two packs using a Multiplex without taking the outer shell apart.
Any suggestions?
