RCU Forums - View Single Post - jagdpanther spare track bracket
Old 05-28-2009 | 07:19 PM
M.A.Ts
Default RE: jagdpanther spare track bracket
daisy this is what i did, just lay three sections of track side by side with about 0.5mm separating them now you have your length & follow Tanques technic for the u brackets, I drilled a hole in the bottom of the u bracket & solder some brass rod in to make a spigot, I used plastic strip (4mm w x 1,5mm thick) for the base then drilled holes to attach the u brackets.
