<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><span style="font-size: small;"><span style="font-family: Arial;">
</span></span><link rel="File-List" href="file:///C:\DOCUME~1\Gerhardp\LOCALS~1\Temp\msohtml1\01\cli p_filelist.xml" /><span style="font-size: small;"><span style="font-family: Arial;">Hi Siclick33, there is not too much fuss about the Weatronic systems, because there are not too many issues to deal with. Once you get acquainted with the system, there is not much that people had problems with. Since all the power systems and servo settings are integrated into the dual receiver unit, no interference issues will occur if you follow the guidelines.
In regards to the 2.4 dual receiver systems, it is being delivered to first customers as the small version (Dual Micro series) right now and the big Dual receivers (R-series) will be following soon.
It has even more features and abilities that are unmatched. You don't have to touch them, but they are available, once you choose to use them. Even the Micro dual receivers are fully programmable. Yet you can use them without the help of a computer. (plug and play)
For example Fail-Safe options: You have two Fail Safe's available. One is the channel Fail-Safe and the other is the servo Fail-Safe. Should you choose to activate the servo Fail-Safe, it will override the channel Fail-Safe. Why? .... You could want to program Fail-Safe to lower the flaps and deflect both ailerons full up to cause as much drag as possible. This is just one example.
You can download a small brochure from the following website </span></span><span style="font-size: x-small;">
<span style="font-size: small;"><span style="font-family: Arial;">www.weatronic-usa.com</span></span></span><span style="font-size: small;"><span style="font-family: Arial;"> and check out some more features of the new 2.4 system. Pricing is also very compatible and with the Micro series you have the option of trying out many of the features without having to commit to a full system.
Cheers,
</span>
Gerhard</span></meta></meta></meta></meta>
