RE: FUNJET
Hi all.
I've finally got my new HET 2W20 Typhoon motor and Lightning 80A esc. I am going to be building the FJ today fly tomorrow.
I have 6 of the Outrage 4s1p 2200mAh 25C Lipos as the power supply.
The only thing now is which prop is going to be pushing my little beast of speed. Ihave following :
4.1 x 4.1E
4.5 x 4.5 6 x 5.5 APC
4.75 x 4.75 APC
5.5 x 4.5 APC EP
6 x 4 (standard for the Stryker 27C).
6 x 5.5E APC
7 x4 Windsor Prop ( great for the stryker I had)
Anyone tried to swing a 8x4?
The HET specs are:
EDF2W20 weighs 93g
3350rpm
1.1 Inches Diameter 54mm in lenghth
700W of Nominal power
20mm Rotor Length in mm
50 Max amps.
The Lightning ESC
is 80A Burst current (>10s) 100A
switch BEC
Bec ouput 5v/3A
weighs 62g
size is 70*31*14 (L*W*H).
Hope that about covers the nerdie stuff. I will have the fuse done by the end of today Saturday 30th May.
Hope some one out there can give me the prop to match and give this beast a right kick'n' tomorrow... Am really excited about the finished FJ. Will post pics as it's done.
Cheers to all you out there for all the info I have read over the last few months it's been so helpful on many many levels.
