Sandable plastic filler???
The wheel pant wire slots for the Sportster kit is designed for the taildragger and not for a tricycle gear, so in order to use it for tricycle gear the wire slot will need to be filled in, as well as the drilled holes and screwdriver holes.
Is there a plastic filler that can be sanded smooth so that it won't show underneath the paint?
