RCU Forums - View Single Post - Wheel pants at sharp angle
Old 05-30-2009 | 12:56 AM
jrcaster's Avatar
jrcaster
Default RE: Wheel pants at sharp angle
Oops! guess I am a little late.  I was going to suggest using heat.  You could have used a trim sealing iron to re-shape the plastic so you wouldn't have had to use as much filler.  </p>
</p>
You should let that set up overnight so the epoxy won't load up the sandpaper as bad.</p>
