RE: Help with covering
Ken,
Thanks for your time. I did overlap the two colors on a piece of glass just asyou described. Ithen applied what I thought would be enough heat to join them but not so much as to shrink them. Once Ithought the two were then one, Ilifted them off as one piece and applied them to the framework.
I may just have to experiment with a bit moreheat to join them. Like Isaid, it worked before on the horizontalstabilizerbut I just didn't write anything down about the exact iron setting Iused. I'mhoping to avoidwasting any more material by soliciting the experience of others.
It will be a couple of weeks before I can work on the project again. However,when/if I find a solution, I'll post it.
Thanks again for your time. I'm open to any otherthoughts or advise. (other than buying ARF)
Greg
