RCU Forums - View Single Post - Tuned pipe tuning problems
Old 05-31-2009 | 11:16 PM
DarZeelon's Avatar
DarZeelon
Default RE: Tuned pipe tuning problems
ORIGINAL: anuthabubba
You might want to consider a Magic Muffler type mini-pipe such as the JettStream, MVVS 3253, UltraThrust or even a home made mousse-can type. These offer a broader range of rpm boost along with better throttling response. Some report as much as 1,400 RPM boost (in high RPM engine setups) with these types of exhausts. You would surely get several hundred more rpm.
The nice things about the MVVS item, are its relative low cost and the fact that the header will fit unaltered onto the Fox's exhaust stack.
The JettStream and the UltraThrust need/offer an adapter, since their design is for bolt-through mounting, yet are a rigid, 'one-piece' setup; while the MVVS mounts with a silicone couple, like a normal tuned-pipe.
